Last edit by: IB Advertising
See related guides and technical advice from our community experts
- Chevrolet Silverado GMT900 How to Replace Air Filter
Step by step instructions for do-it-yourself repairs.
Check engine light is on.
When the Check Engine Light is triggered by the infamous loose gas cap, will it eventually reset by itself or does it have to be manually reset?
Is there anyway to reset the codes without a code reader tool?
Well you can always pull the battery cable off. But, if you take it to any major chain auto parts store ( I know Advance Auto and Autozone are do), they will read your check engine codes and reset them free of charge.
Same issue with my 08 Silverado. Dealership knows the problem and it is common. The part about dusty environments is garbage. They were going to charge $400 to fix. I carried it somewhere else and paid a little more. Between this, the speaker issue, hard shifting, and having to replace my discolored rear-end fluid at 27,000 miles, I really don't think I will buy another Chevy or GM product. It's a pitty. I thought I was doing good buying American, but Chevy doesn't give a darn about its customers. That's my soap box rant.
The check engine light on my 2009 Silverado came on and I had Auto Zone read the code. He told me my my gas cap probably had dirt on the seal and if I cleaned it and the neck of the filler tube, it would turn off. Well it didn't so I went to the dealer and bought a new cap and that didn't make any difference either. Now I am wondering if it is one of those solenoids or a saturated charcoal canister. The dealer said that solenoid is on top of the gas tank and to test it, they would have to do a smoke test. My truck only has 37,388 miles, which seems too few miles to be having this kind of problem. Seems like it should be covered by warranty since it is emissions related. If the problem was caused by over filling the gas tank, does it ever dry itself out and cure itself, or do you have to pay the long dollar to fix the problem? Right now is not the best time of year to have a large expense. Would it hurt anything if I don't get it repaired? The truck seems to run fine otherwise.
Harv
Harv
Tech 2 asked what the code was that caused the check engine light. It was PO442 which from what I understand is a small leak of .020". I replaced the gas cap and that did no good. I checked the evap solenoid which is also OK. I don't know what to do or check next, Maybe someone knowledgeable in this area could give me some help. Thanks.
Harv
Harv
I still don't know where to go to find the cause of the check engine light (code PO442) on my 2009 Silverado 1500. I replaced the gas cap and checked the evap solenoid and it tested good but the light is still on after a week and a half. Note, this truck does not get a lot of miles as it is only driven about 2 to 3 times a week and usually for very short distances of about 6 miles. An Auto Zone guy read the code and when he checked it again after checking the evap solenoid and replacing the gas cap with a Chevy one, he said he couldn't reset it. I guess I can unhook a battery lead and reset it that way and see if the light comes back on. Any suggestions on what to do next? The dealer said they could do a smoke test for $60, so maybe I will have to go that route if no one has any ideas.
Harv
Harv
o.valdez
Dec 17, 2011 10:46 PM
93chevyman
Mar 12, 2010 1:13 PM
