Old Aug 11, 2015, 1:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Check engine light blinking
Old Apr 21, 2013 | 7:40 PM
njoe's Avatar
Default Check engine light blinking
My 2000 Silverado z71 check engine light blinks when i accelerate and loses power bad, i changed all the plugs and wires but it is still the same. Any input would be greatly appreciated.
Old Apr 21, 2013 | 8:10 PM
kevinkpk's Avatar
plugged exhuast or fuel related. It probably is a 300 code misfire.
Old Apr 22, 2013 | 12:05 PM
jcgonzal's Avatar
Yeah, I thought with pretty much all vehicles a blinking light meant engine misfire. Does the light stay on solid otherwise? Possibly a coil?
Old May 27, 2013 | 10:36 AM
Dustyin's Avatar
Try pulling spark plug wires off one at a time reinstalling them after you pull it off and Listen to the engine as you are pulling them off. If you pull the spark plug wire off of spark plug and it misfires more, its good. If you pull the spark plug wire off and nothing changes you found the source. Chances are you have a bad coil.
Old May 27, 2013 | 12:03 PM
WyattChevy's Avatar
Most of the time the code will also let you know what cylinder the misfire is on. Commonly the spark plugs or coil, rarely the wires
Old May 27, 2013 | 4:50 PM
ukrkoz's Avatar
Why don't you read error codes? They have specific error code per each misfiring cylinder. IF it's misfiring.
350Life
Jan 6, 2014 7:04 AM
Georgiaboy04
Jul 13, 2013 9:38 AM
taterball
Jun 25, 2012 10:14 PM
mmstone24
Sep 18, 2009 11:08 PM
sjp240
K5 Blazer
Feb 23, 2008 8:40 PM
