Check engine P0449 confused
Old Sep 13, 2012 | 4:05 AM
Christopher Krumholt's Avatar
Default Check engine P0449 confused
I was getting a code P0449 which is the Evap vent. When I left work my check engine light was not on like it usually is and i got a dash warning saying tighten gas cap. I just got a new gas cap. Im going to replace the vent next week. Im getting a P0332 also knock sen.
Old Sep 13, 2012 | 10:40 AM
country_09's Avatar
Probably a dirty vent valve, and change the knock sensor. Usually its the one further up on the block. Water gets in and damages the sensor. Put some high temp rtv around the hole for the sensor and it should be good to go
Old Sep 13, 2012 | 12:45 PM
So u know how easy it is to change the knock sensor?
Old Sep 13, 2012 | 2:52 PM
kevinkpk's Avatar
I believe the knock sensor resides in the ecu.
Old Sep 13, 2012 | 6:12 PM
country_09's Avatar
If its like mine was, you have to pull the intake manifold off. Took around 3 hours to do
Old Sep 13, 2012 | 6:52 PM
How hard was it?
Old Sep 13, 2012 | 9:01 PM
country_09's Avatar
Not hard at all just took some time. Gotta remember where everything plugs into. The injector rails have to come out along with all the wiring. What year is the truck?
Old Sep 14, 2012 | 3:29 AM
2006. Hope the sensor isn't to much
Old Sep 14, 2012 | 8:16 AM
country_09's Avatar
The sensor itself wasn't expensive, just takes a lil bit of know how to replace it. But it's not hard at all
Old Sep 22, 2012 | 2:18 PM
Discount Car Parts Stuff - Car Accessories & Truck Accessories - Cheap Auto Parts - Car Cover - Floor Mats - Cargo Liner - knock sensor - 2006 Chevrolet Silverado 1500 Knock Sensor
does 20$ sound right?
