Check Engine Stabilitrak
Old Aug 27, 2020 | 9:28 PM
choangc's Avatar
Newly Registered
Unhappy Check Engine Stabilitrak
Please help, we have tried EVERYTHING and are already $1000 deep in parts replaced.
I recently purchased a 2007 Silverado 1500 Crew 5.3L
Upon getting home the check engine light came on. Code was P0335 (Crankshaft Position Sensor A Circuit) along with it came the notification for stabilitrak which would also cause rough shifting at low gears and the engine to stall occasionally at idle. Reset the battery/codes and truck runs fine zero issues till code comes back on.
We replaced:
-Crankshaft sensor and connector wire
-Camshaft sensor
-Timing chain (tensioner, sprocket, etc)
-Spark plugs and wires
-Fuel pump (had low pressure and would decrease over time)
After this everything ran fine no codes no issues. Took it off the lift and for a test drive and the check engine light is back on and so is StabiliTrak message.
Ran the codes and came up as P0335 (Crankshaft Position Sensor A Circuit) and P0455 (Evap Emissions System large leak detected)
I am at my wits ends and my pockets are about empty... I don't know what else we could possibly replace. Please help.
Natasha Lennex
Nov 12, 2025 11:20 PM
lamberts
Oct 23, 2017 12:10 PM
sam_moening
Sep 5, 2017 12:21 PM
Grumpkins
Feb 10, 2015 8:32 AM
25homes
Nov 20, 2012 4:45 PM
