Chevorlet 2003 HD 2500 turn signal problems
Turn on left signal, blinks untill I put foot on brake then stops. If I leave foot on brake and turn signal off then back on both tail lights and third brake light flash. Was told this is a brake light switch problem, if so is this something i can replace or take it to the shop ? Thanks in advance for everyones help.
Should be an ez fix, I would follow wiring from the turn signal itself to the switch as well...Sounds really like a relay is out, if thats the case, its a plug n play fix, simply locate the relay/switch pull it out and get a new one in its place...if in fact that is ur problem, than its as easy as pulling a plug from a house socket and putting different one in. Good luck
edwarda10pilot
July 28th, 2019 12:19 PM
fishingpro77
HHR
August 4th, 2016 12:44 AM
WesleyB57
Avalanche
September 21st, 2013 9:30 AM
RomanGuzi
October 2nd, 2011 11:40 AM
