Notices
Clunk in rear end when turning
Old April 30th, 2009, 5:56 PM
  #21
Ride of the Month
May 2009
mudmaniac's Avatar
It sounds like the main issue here is expense. Jack it up, pull the cover, put it in neutral and give it a spin while looking at the spyder gears. That will cost you nothing. If the spyder gears need replacing you need to 1st remove the bolt holding the cross shaft in place then push the axels in 1 at a time and remove the c clip.
Pull the axels out enough to allow the removal of the 4 spyder gears and at that point rotate the drive shaft by hand and see if the carrier spins smothly on the ring, pinion and carrier bearings. If it does then simply replace the spyder gears, slide in the axels 1 at a time and install each c clip then reinstall the cross shaft, seal the cover back on and refill.
That would only cost you the spyder gears and some fluid.
If it needs more than that and you have never set up a rear before, get some help.
Old April 30th, 2009, 7:24 PM
  #22
fsh4fun05's Avatar
That's the kind of answer I was hoping to see. We'll see how it goes.
Old May 11th, 2009, 8:13 PM
  #23
fsh4fun05's Avatar
Well, I don't know if I got ripped off or not but I do know that my truck is fixed and that's what really matters to me. The mechanic ended up replacing the diff with a AAM Helical Limited Slip Differential (pt # 40041224). He gave me my old diff and I took some pics. I'm surprised I made it to the mechanic. Total was $1300 and some change.
Attached Thumbnails Clunk in rear end when turning-imgp02451.jpg   Clunk in rear end when turning-imgp02471.jpg   Clunk in rear end when turning-imgp02481.jpg
Old May 11th, 2009, 8:53 PM
  #24
suzuki-guy's Avatar
Not to bad it cost me about 400 but i did it my self and got my diff carrier cheap! I would of did it for 100 bucks and a case of beer lol
Old May 15th, 2009, 11:06 PM
  #25
fsh4fun05's Avatar
I'd rather pay for quality and a sober mechanic
Old January 26th, 2023, 8:01 PM
  #26
3ch0_I7's Avatar
Originally Posted by fsh4fun05
I got home from work and in a hurry I started draining the diff. My intentions were to take the cover off and inspect but a nasty cold storm blew in and started dumping on me. I was able to drain the old fluid, it was black, and replace it with Lucas and the gm additive. My wallet felt some pain when I looked at the drain plug and there were two tiny teeth on top of it. About the thickness of a toothpick and about a 1/4 inch long. I did the best I could to scrape the bottom through the drain plug but found no other metal bits. I stuck my finger in the hole,lol, and felt the bottom of the diff. My finger had stripper sparkles on it when I wiped it off. (tiny metal flakes like dust) Took it for a spin around the block and then turned into a parking lot so I could do some turns. Damn it! The wheels still skip!!! I turned the wheel all the way to the left and watched the left rear tire come to a complete stop when I let off the gas. I slowly straightened out the front wheels and the truck started rolling again (it's an automatic). Why would it bind up like that?
I replaced the u-joints and the carrier bearing on the two-piece driveshaft about two months before I had this problem. That wouldn't have anything to do with it, would it? I really need to find out what's wrong but at the same time I need to find out WHY it went wrong.
Broken truck=no fishing....it's a sad day.
I own a 2003 chevy suburban and this same issue happens to me. From reading your post, looking at rear diff diagrams for that generation model rear diff I have come to the conclusion that this is happening: I know for a fact that my 03 has an automatic locking rear end. If you come to a complete stop, up until about 20 mph it'll stay locked. It sounds like there are teeth that are missing, causing the locked diff to jump teeth causing a clunk and a quick shift of power between wheels. I haven't looked at or changed my diff fluid in 95 thousand odd miles, but I imaging it will look like yours.
bustersdaddy
April 1st, 2017 3:54 PM
marbles 1965
September 30th, 2013 8:51 AM
parker12
August 26th, 2011 3:16 PM
ukrkoz
May 31st, 2009 9:50 PM
Gypsy
April 8th, 2008 9:56 PM
Quick Reply: Clunk in rear end when turning
