Clutch lever arm assembly
Old Feb 26, 2012 | 5:48 PM
Johnny B.'s Avatar
Default Clutch lever arm assembly
Hello. On my 2001 Silverado 5spd 6cyl truck my clutch lever arm assembly broke right where the Clutch master cylinder attaches on the inside of the engine compartment(Round plastic piece that the cyl locks onto). In order to replace that I had to remove it from under the dash on the inside of the cab. The clutch pedal is also attached to it, however I cannot get it out from under the dash..Not much in the way of clearance.. What do I need to do? Everything is loose as far as the assembly is concerned and ready to pull out.. HELP!!
pdrayton
10
May 5, 2024 2:27 PM
juliem
Sep 22, 2015 7:01 PM
Chevyaz
Mar 14, 2013 10:58 AM
Muskovin
Feb 24, 2013 5:13 PM
maxxman04
Mar 9, 2010 5:34 PM
