Code P0300?
Old Oct 18, 2013 | 7:12 AM
white03's Avatar
Default Code P0300?
Does this mean I should change plugs and wires? What other things could it be?
Old Oct 18, 2013 | 10:42 AM
Fishinfooleric10@aol.com's Avatar
the code is a random misfire could be bad plugs, wires, vacuum leak, PCM. It can many things because multiple things can cause a misfire. Tell us the year and size motor and maybe a description, does it come and go or stay, is your truck running really rough, or anything else that can help us figure it out.
Old Oct 19, 2013 | 6:08 AM
white03's Avatar
Its a 2003 5.3, it comes and goes, mainly when idling after im going down the road its fine
Old Oct 24, 2013 | 12:17 PM
brucegregory's Avatar
my 05 with a 4.8 same motor just different pistons,crank and rods has the same problem, i do not get a check engine light but when i tried to get a inspection it has this code, i also would get a pop thru the intake when taking off sometimes. i changed the intake gasket,this helped the intake leak.there are 2 different gsts i bought the most expensive one,i changed plugs and wires but still have random misfire.do not know where to look next
advanceauto
Feb 27, 2010 9:51 AM
tat2dup81
Sep 28, 2009 6:16 PM
mkabwilliams
Jan 17, 2008 2:22 PM
07TahoeLTZ
Mar 30, 2007 11:51 PM
warrennaujalis
Oct 28, 2006 10:24 AM
