Code P307- Mysfire Cyl 7 wont go!!
Old Feb 29, 2012 | 7:58 PM
Tavo Govea's Avatar
Default Code P307- Mysfire Cyl 7 wont go!!
I have a Silverado 2006 Crew Cab 5.3l 4x4 and the check engine light is on. the scanner says P307, so i changed the spark plugs, the wires, checked the coils, checked the fuel pump pressure, got the injectors cleansed, then erased the code but i appeared again. any ideas?
Old Mar 1, 2012 | 5:16 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Tavo Govea,
Are you sure the coils and injectors are okay? You may want to consider taking it in for a quick inspection. A certified technician should be able to offer a more accurate diagnosis after a physical inspection.
Please keep us posted.
Louis
GM Customer Service
Tavo Govea
Jan 13, 2025 3:10 PM
chrisk
Jul 6, 2016 7:14 PM
philgethifi
16
May 27, 2009 11:52 PM
Gwampa
Apr 1, 2009 9:27 PM
