Coolant dissapearing????
Old Jul 23, 2007 | 10:40 AM
2001 2500's Avatar
Default Coolant dissapearing????
As you can tell by my name I have a 2001 2500HD with the 6.0L. My question is why do I keep losing coolant. I lose about a 1/2 inch in the resevoir every 2-3 weeks. There is not obvios signs of smoke so can't tell where the leak may be coming from. I have had it to the dealer and they cannot figure it out either.
Any suggestions????
I haul a 25ft. 5th wheel and am going to be taking a long road trip in Oct. I need to get this figured out.
Thanks,
Chris
Old Jul 23, 2007 | 11:50 AM
ZX1100F1's Avatar
Default RE: Coolant dissapearing????
There were a few bad cylinder head castings on the 5.3L and 4.8L engines back then but none on the 6.0L that I am aware of.
The most likely cause of coolant consumption is a bad head gasket.
Old Jul 23, 2007 | 1:47 PM
Fireguy8's Avatar
Also you can check the intake gasket at the rear of the engine at one of the rearmost coolant ports,they sometimes only leak under pressure.
Old Jul 23, 2007 | 4:06 PM
ZX1100F1's Avatar
There are no coolant passages on the 6.0L Vortec Powerplant intake manifold.
Old Jul 23, 2007 | 10:32 PM
Waboom!!'s Avatar
Banned
I had a slight water pump leak on my 03 that was never visible or detectable that caused me to lose a similer amount of coolant.
Old Jul 23, 2007 | 11:13 PM
cj23's Avatar
I have a 01 5.3 water pump waschange but still add coolant every month or so no visible leak, no smoke and plugs look good. So where is it going?
[/align]
Old Jul 24, 2007 | 8:09 AM
2001 2500's Avatar
That is the wierd thing for me too. No smoke, no leak on the ground, plugs look good. Can't seem to find anything.
Help?????
Old Jul 29, 2007 | 4:28 PM
azchevygirl's Avatar
I have a 2002 1500 1/2 ton that started doing the same thing....turned out to be a slow leak in the bottom of my water pump.
Old Feb 7, 2008 | 2:52 AM
wcrank's Avatar
I have been having the same trouble with my 2000 silverado. I still can not find it.
Old Feb 7, 2008 | 11:36 AM
slc10844's Avatar
If there are no leaks, it may be the cylinder head or head gasket.
