Notices
coolant leak that I can not locate
Old December 3rd, 2010, 4:14 PM
  #21
Nissan_Ranger's Avatar
Originally Posted by RakerBill
There are a series of freeze plugs around the engine to protect it in the event of the antifreeze/water freezing in the block. They will pop out so as not the crack the block.
After a while they will start to leak, and they will drip antifreeze around the edges. They are easy to replace depending on where they are at.
I have had several rigs over the years start to leak behind the bellhousing on the rear of the engine. If that is the case, the engine, or tranny will have to come out to replace them.
2 wheel drives won't be too bad cause you won't have to deal with the transfer case.
The frost plugs in an engine casting are there as a result of the casting process during manufacture. They are not intended to protect the block and in fact will not prevent freezing damage.
Old December 4th, 2010, 10:36 PM
  #22
silverado13's Avatar
yeah antifreeze is the only protection
skram
July 30th, 2015 8:03 PM
nycjoshuad
May 30th, 2014 2:04 AM
95wt
May 30th, 2008 3:07 PM
moerome
January 26th, 2008 1:23 PM
doo600
August 17th, 2007 8:26 PM
Quick Reply: coolant leak that I can not locate
