Crankshaft R & R
#11
Professional Mechanic
Yes you would have to pull or slide the trans to do it in order to remove the fly wheel. Just to say it again I HIGHLY doubt that is your problem. Doing it outside on the ground will take you days to complete. When you pull the oil pan and the crank is not broken you will have done lots of work for nothing. It sound more like you need to re investigate the clutch, clutch master cylinder, clutch slave cylinder and transmission.
#12
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
#15
I'm in the process of trying to get it out to the country to pull the engine. I could use some suggestions on what would cause that.
Also How much worse would it make the gas MPG, if I put in 383 kit in it.
silverado man
May 18th, 2017 12:05 PM
