dash light
The cluster easy to get out (ten minutes or less), once you get it out you can check the lights to see if they are burned out or just a bad connection.
to get the cluster out;
1. pull the front bezzel off, you willneed to disconect Head light, dome light, and fog light switches once the bezzel is loose (itshould just pull apart from the dash, no screws to undo).
2. unscrew the four scwrews holding the cluster on (you will need a small socket driver)
3. then pull the cluster out, and check the light bulbs
If it is the bulbs then you should be able to get replacements at anauto zone, kellys, or your local auto parts store.
To put back together just reverse the order in which you took it out.
P.S. If you have and auto trans. you my need to move the shifter all way way into 1st gear to make more room to get the bezzel off.
whitesox1933
July 28th, 2012 8:13 PM
beckya99
July 12th, 2011 12:29 PM
Deteoni
March 28th, 2009 1:39 PM
