Dash lights on '06 Silverado W/T
Quick question for everybody: Is the little wheel (and the corresponding symbols) for the interior dash light dimmer/dome light switch supposed to be illuminated at night? My headlight switch is, as well as the cargo light symbol, but not the dimmer switch. I was wondering if I have a burnt out bulb, or if GM just cut corners on the work truck. Thanks for your time.
--John
'06 Silverado W/T
--John
'06 Silverado W/T
RE: Dash lights on '06 Silverado W/T
Ref: 2006 Silverado (regardless of trim)
The following switches and components have back lighting when the park lamps are on:
(provided truck is equipped with item listed).
The instrument panel cluster (IPC)
Radio, front and rear
Window and heated seat switches
Garage door opener switch
Selectable ride switch
Roof beacon switch
Power take off (PTO) switch
Headlamp leveling switch
Rear wheel steering mode select switch
HVAC control assembly
Headlamp and panel dimmer switch
Transfer case shift control switch
PSIR disable switch
PRNDL lamps
Traction control switch
Steering wheel control switches
Fog lamp switches
Roof beacon switch
PSIR disable switch
PRNDL lamps
Fog lamp switches
devolic
May 18th, 2012 9:04 PM
TxFire
January 10th, 2011 10:29 AM
Big_Jazzer
February 27th, 2009 1:25 PM
