Old Jul 24, 2015, 4:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
diesel to gas conversion
Old Jul 9, 2007 | 9:03 AM
bigred808's Avatar
Default diesel to gas conversion
does anybody know what the fuel flow is suppose to be? I converted this truck from diesel to gas and I am buttoning things up right now, but fuel seems to be my last "big" problem I have tried to avoid switching out the sending unit in the tank and ran an external pump, factory pressure on the fuel system is 9-13 so I bought a 10-14 psi pump, well she will idle fine but if you hammer on it it stumbles and takes a few seconds to come to life, and you can definitly tell the spray pattern in the injectors does not pick up right away. My buddy told me the it may have the pressure but not the flow (gph.... i assume gallons per hour) anyways if there is any buddy that has done this or knows about the fuel flow and pressure I would sure like to hear from you!!
1995 body with a 91 5.7 fuel injected engine, K1500
Old Jul 10, 2007 | 12:57 PM
cheyenne06's Avatar
Default RE: diesel to gas conversion
You converted from Diesel to Gas?? Why on earth would anyone do that?? You can get so muchmore power out of a diesel, not to mention they're better for MPG, and the fuel costs less.
Good luck finding an answer as I haven't heard of this scenario before.
Old Jul 10, 2007 | 1:39 PM
ZX1100F1's Avatar
You'll need to get the OEM fule pump that puts out 50+ psi pressure.
Old Nov 26, 2008 | 1:50 PM
woody_texas's Avatar
My brother did the same and he had to change out the fuel lines to get it to run right
Old Nov 26, 2008 | 6:14 PM
bubba33's Avatar
ORIGINAL: cheyenne06
Not with the diesel that he had. Those were a P.O.S
Old Nov 26, 2008 | 6:40 PM
EvansBlue's Avatar
This thread is more than a year old...[/align]
ahearnm
Mar 19, 2023 6:37 PM
Marcus Worth
Cruze
Jul 31, 2013 2:31 PM
Chevy_Bigrig
Dec 2, 2010 1:42 PM
sierraZ71starcraftGT
Jan 17, 2008 4:22 PM
WMBigs
Dec 13, 2006 1:24 AM
