differential/ cv axle question
Old Nov 5, 2012 | 10:18 PM
nkh34's Avatar
Default differential/ cv axle question
So i feel dumb having to ask this but im having a hard time figuring this out. the cv axle bolts to another axle typed part that goes into the diff. well thats pulling out of the diff. and its leaking fluid and id rather get it fixed before the diff. goes bad. i can see the seal and its cracked and in bad shape.
thanks for your time
Attached Thumbnails differential/ cv axle question-cv-axle.png
Old Nov 5, 2012 | 10:42 PM
nkh34's Avatar
and im also tryin to find a 5 light cab visor if anyone knows a good place to get one please let me know
Old Nov 6, 2012 | 7:58 AM
country_09's Avatar
That part that's circled is just the other half of the cv. Just replace the cv and it should be good to go.
Old Nov 6, 2012 | 8:14 PM
nkh34's Avatar
haha sorry thats a bad way to try to show what im asking i need to know the name of the part that the cv bolts up to
Old Nov 7, 2012 | 7:14 AM
country_09's Avatar
The side of the diff housing?
Old Nov 7, 2012 | 10:40 PM
nkh34's Avatar
i think its a drive axle it connects to the cv then goes into the diff.inbetween it and the diff. houseing is a seal and its leaking.
Old Nov 8, 2012 | 10:24 AM
country_09's Avatar
From the sounds of it that is the problem. Take it out and replace it...have fun! Lol
Old Nov 8, 2012 | 11:43 PM
nkh34's Avatar
yeah thats the plan the axle is close to 300 bucks so i think ill pull it out and see if it looks good it should still be fine and hopefully i can just replace the seal i just cant figure out how the dang thing popped out like it did ill try to put a picture of it up so you can actually see what im having such a hard time explaining.
as always thanks for your help and time
Old Nov 9, 2012 | 8:23 PM
cleveland63b's Avatar
you said it looks like its hanging out of the diff?? does it have a lot of play where it goes in the diff?? may need to open the diff up and check for bearing failure
Old Apr 21, 2015 | 9:41 AM
ironman67's Avatar
Default http://chevroletforum.com/forum/silverado-fullsize-pick-ups-21/differential-cv-axle-q
I am having same problem and had the differential rebuilt new bearings and seals new outer housing less then two weeks ago and is now worse then it was before.. is the cv axle supposed to move in and out? the movement and leaking is from the pass side ive also put 2 front drivers side hubs on with in 5 months .. what could possibly make it go bad that fast... now idle arm and pitman arm are bad as well
Afazakerley
Nov 15, 2013 4:26 PM
DC_443
Dec 2, 2011 3:10 PM
tbb2
Aug 13, 2011 7:06 PM
94G20
Mar 29, 2011 3:42 PM
itlldue
Jul 28, 2008 10:18 AM
