Differential Question
Old Jul 13, 2008 | 6:44 PM
itlldue's Avatar
Default Differential Question
I have a 2007 Silverado with the GU5 differential, JF7 option.
Can I replace it with a GU5, JF3 differential without it affecting the computer or ABS?
(It was wrecked with 1307 miles)
Old Jul 13, 2008 | 6:45 PM
itlldue's Avatar
Default RE: Differential Question
Follow up -I can't ask Chevrolet because they want the VIN number and will probably void the warranty if they know I changed it.
Old Jul 27, 2008 | 12:26 PM
itlldue's Avatar
Bump
Anyone?
Old Jul 27, 2008 | 2:00 PM
therewolf's Avatar
I do know you need to be absolutely certain the front diff and rear diff are the same gear ratio. Also, the abs sensor responds at highway speeds, and will trigger a service instruction if you do a gear ratio change. Did GM use JF7 and JF3 interchangeably,or
Old Jul 27, 2008 | 2:04 PM
therewolf's Avatar
was the JF7 an upgrade performance modification, or what? Primarily, you need to know the JF3 and your front diff are the same ratio, then work from there. A 4x4 specialist shops that deals with upgrades and changes would probably be able to tell you, if the
Old Jul 27, 2008 | 2:05 PM
therewolf's Avatar
interchange manual sheds no light on the issue.
Old Jul 28, 2008 | 10:18 AM
itlldue's Avatar
Two wheel drive.
JF7 - 6400# rear axle
JF3 - 7000# rear axle
Johnnybourban
Jun 22, 2015 3:07 AM
nkh34
Apr 21, 2015 9:41 AM
gmlover
Oct 30, 2013 8:24 PM
rcellis2
Apr 19, 2013 12:30 PM
94G20
Mar 29, 2011 3:42 PM
