Do i need an alignment after removing my 3 inch body lift?
Old Apr 23, 2012 | 9:00 AM
jacobd101's Avatar
Default Do i need an alignment after removing my 3 inch body lift?
I spent saturday removing my 3 inch body lift on my 96 z71 and i think i need an alignment but i thought i'd get the input of you guys first. The steering wheel seems to be to the right a little bit so this is why i think i need one. All responses are appreciated, thanks a lot.
Old Apr 23, 2012 | 8:07 PM
avgas's Avatar
Yes You do need to get one.
Old Apr 23, 2012 | 8:26 PM
Doug Roberts's Avatar
Body lift then no if it was only body lift
Old Apr 23, 2012 | 9:37 PM
cleveland63b's Avatar
if it was a body lift you shouldn't depending what all it had....suspension definately
Old Apr 24, 2012 | 8:46 AM
jacobd101's Avatar
I removed only the 3 inch body lift it still has a 2 inch suspension on it but i just dont understand why it would need an alignment. Think it would have anything to do with the steering linkage? Thanks for the responses guys.
Old Apr 26, 2012 | 8:19 PM
you shouldn't if its just the body lift, thte only thing steering wise that might change is the intermediate shaft length or angle
Old May 10, 2012 | 7:04 AM
jacobd101's Avatar
Well i got an alignment on tuesday and it seemed to fix my problem thought id let you guys know. But on the not so bright side i found out i need new control arm bushing's! anyways thanks for the responses.
lrfjeffers
Aug 17, 2013 12:16 PM
jacobd101
Apr 20, 2012 9:25 AM
wigley11
Apr 27, 2011 9:06 AM
ashetzel
13
Mar 24, 2010 6:42 AM
Biggwaukegan
Feb 18, 2007 12:56 AM
