Electrical problem
Hi all!
I'm working on my friend's 2002 Silverado 1500 LS 5.3L V8 trying to figure out an electrical problem. I borrowed the truck for a day and when I tried to start it, there was a click and everything was dead. From searching, there seem to be several electrical issues with this model so I did some diagnostics to try and narrow it down.
Here's what I've done/found so far:
1) The battery is fully charged and ready to go.
2) I cleaned the two ground connectors to the body under the hood. I could not reach the connection to the block to clean it but could feel it is not loose.
3) There is a relay that clicks every few seconds. The relay has part# 8567 on it and it is in a slot (in the relay block on the driver's side under the dash) marked "INADV PWR Relay" in the AllData manual. The relay below it marked "CTSY Lamp Relay" is the same relay so I swapped them to see if it was just the relay, but the other one does the same clicking.
4) When I disconnect the battery and reconnect it, the light under the hood will come on, but nothing in the car comes on. I put the key in the ignition and it dings, but once the key is turned everything goes completely dead.
Any ideas as to what would cause this kind of problem? In my cars, it's usually a ground fault that causes freaky electrical problems like this, but I have only found the two grounds under the hood and they are both clean.
Thanks!
Thanks!
Thanks. I got a similar answer on another forum, but I checked the connectors and cleaned them and forgot to post that part. I will go through them again and see if I can find a break in the line.
My friend did say that one of the grounds from the battery had a break in the middle of it under the sheathing about 5 years ago. Maybe it happened again.
I have this exact issue. It started right after I got me new trailer home. I turned off the truck to unhitch the trailer and then when I tried to start the truck.. nothing, and the same clicking from the same relay. connections are clean and jumping it does not help. It actually started briefly after sitting on jumper cables for a while but would die immediately. Any thought?
mine wound up being a bad battery. I replaced the starter and the ignition switch with no change to the problem. I hooked up jumper cables and it started right up. Took the battery to get tested, sure enough, bad battery. Put in a new one, fixed me right up. Never had a bad battery act like this before.
Like you said Bad Battery. Replaced it and it cranked right up! Lifesaver
