Emergency Brake Indicator Light
Old Jul 10, 2007 | 2:07 PM
bkordrs's Avatar
Default Emergency Brake Indicator Light
The Emergency Brake Indicator remains lit after I release the brake. When I engage the brake the indicator light brightness increases.
Old Jul 10, 2007 | 2:23 PM
cheyenne06's Avatar
Default RE: Emergency Brake Indicator Light
The light is activated by a pressure switch on the pedal. Check to see if the switch is out all the way when released. If it is, check you brake lights to see if they all work. Some vehicles have a setup where if a light goes out, a light on the dash lights up.
Old Jul 10, 2007 | 3:07 PM
techrecruit's Avatar
Usually an indicator of a faulty brake light or tail light
Old Jul 10, 2007 | 4:18 PM
golfer's Avatar
ORIGINAL: bkordrs
Does it light even though you don't engage the park brake ?
If it does there may be a problem with low brake fluid or the sensor.
Old May 15, 2011 | 11:05 AM
gemlam's Avatar
I am having a similar problem. When I release the emergency brake, the warning lamp does not go off completely - it stays on very dimly. Even when I turn off the ignition, and remove the key, the lamp stays on very dim.
jg33
Jan 3, 2021 3:17 PM
jrsavoie
Jul 19, 2012 2:36 PM
diane888
Aug 8, 2007 4:38 PM
diane888
Aug 5, 2007 9:46 PM
LouisT
Nov 13, 2006 6:54 PM
