Engine Stumbles at take-off
#11
Id say you have a bad MAF, when mine went bad it did the same thing, bank 1 lean codes & such. Man, when I unplugged my MAF it ran like a bat out of hell, never felt it so fast, it felt like a camaro. The computer would adjust the best it could and it would go back to normal accel after a few hours. I installed the new MAF and all codes went away and it ran normal. I do miss the way it ran confusing the computer by unplugging it, that was fun, but I like it to run the way its designed to.
#15
I have the same stumbling issue, I think it is Fuel Related tho, also if you have an exhaust leak like me it will contribute heavily to the stumbling. Especially if it’s up to the front of the truck like mine. The Upstream sensor and Downstream sensors get freaked out and do not know what to do, they could also be bad. I have the codes P0137, P0157, and P0161. They’re all 02 Sensor Related. I also have the P1870. I think it may have went away tho, my truck never ever slipped, it may have been just a bit off with the input speed sensor and the output, I used some Lucas Trans Fix and my fluid was a bit over the line so I fixed it and I haven’t had any really bad issues. But if you have any existing Exhaust leaks, any bad wiring, etc id get it fixed and then see what it does. My engine light went out on it’s own once and then came back after I gave my truck the sauce down the highway. Must be that 02 code.
tom5170
March 16th, 2010 9:41 PM
Big_al258
November 3rd, 2009 4:06 PM
