How do I take the radiator fan off to take off the water pump in a 93 silverado?
Old Mar 16, 2010 | 8:37 PM
tom5170's Avatar
Default How do I take the radiator fan off to take off the water pump in a 93 silverado?
I loosened all the bolts, even on the water pump. The problem is that I cannot figure out how the thing on the back of the fan off so I can slide the pulley off and take the water pump out.
The thing is like the front of the fan and it needs to come off so I can get the fan off.
Old Mar 16, 2010 | 9:13 PM
nauticstar87's Avatar
There should be four bolts on the pulley, take those off and pull the pulley off, the fan will come with it. You have to use a wrench, not a ratchet. I'm saying this from memory, so I could be wrong.
Old Mar 16, 2010 | 9:14 PM
gotstylez's Avatar
x2 on what star said
Old Mar 16, 2010 | 9:25 PM
tom5170's Avatar
I meant the fan drive. How does it come off?
Old Mar 16, 2010 | 9:31 PM
gotstylez's Avatar
fan shroud???? the placstic thing around the fan?
Fan Drive??? You might be talking bout the fan clutch, which shouldn't have to come off to replace the waterpump.
Old Mar 16, 2010 | 9:37 PM
gotstylez's Avatar
take a pic if we cant get it.. its kind of hard guessing...
Old Mar 16, 2010 | 9:40 PM
'Stylez take a look under your hood, if ya feel like it. Or if it's close, SHould be same motor and setup...
Old Mar 16, 2010 | 9:41 PM
gotstylez's Avatar
i did this last year....... take belt off.... undo the fan...
take off the old waterpump.....use a lil gasket maker to hold gasket on.....put it on...and reverse lol
warthogcrewchief
Jul 7, 2024 3:29 PM
Fuel Truck
Feb 14, 2013 2:18 PM
cristie
Apr 24, 2008 2:54 AM
STRAYDOG
Jan 11, 2008 2:51 PM
