EST Wire To time the Engine
Do you have a vortec engine? Black plastic intake with t-body in the middle? If so there is no wire and you can not set ignition timing with a light it is computer controlled. Turning the distributor is used for fuel injector timing and syncs to cam and crank sensor. It must be done with a scan tool that shows data.
gunner5
September 22nd, 2009 5:08 PM
