Notices
EVAP Question 2000 Silverado
Old April 4th, 2011, 9:54 PM
gerkendave's Avatar
Default EVAP Question 2000 Silverado
Wondering if anyone can point me in the right direction to solve my ses light. When i pull the code the description "EVAP system flow during non-purge". I forgot to write down the code number just hoping someone on here has an idea of what is up with this it is now causing the truck to act as if it is either flooded or starving for fuel but only when stopped at a light after driving. thanks for the help
Old April 4th, 2011, 9:59 PM
gerkendave's Avatar
Also wonderin if anyone as experienced a cold draft while driving. Its only on the passenger side of the pickup comes from under the dash but i can't seem to find it.
Old April 4th, 2011, 10:20 PM
EinST's Avatar
Was the trouble code P1441? If so, it failed the purge valve leak test, i.e., there was vacuum in the fuel tank with the purge solenoid valve closed. I may cause starting problems but usually no driveability problems. On the "cold draft," I've no idea.
Old April 5th, 2011, 8:54 PM
gerkendave's Avatar
Could this be caused by a bad purge solenoid? or something else.
Old April 6th, 2011, 11:37 AM
EinST's Avatar
It could be the purge valve itself or control circuit. The former is easy to tell if you have a vacuum gauge. Take the electrical connector and purge pipe (the vapor line that goes toward the fuel tank) off the purge valve, hook up the vacuum gauge, and then monitor the vacuum level with the engine on. If the valve is leaking, the vacuum level will rise.
malglot
Sonic (Aveo)
14
October 9th, 2022 3:28 AM
namu mac
October 4th, 2012 10:12 PM
97chevy4.3
June 20th, 2009 10:38 PM
tjlandrover
December 4th, 2008 1:13 PM
leomazzone
July 9th, 2008 8:26 PM
Quick Reply: EVAP Question 2000 Silverado
