Exhaust
Well after looking around I do believe that my first upgrade is going to be my Exhaust. I can't run true duels here in VA because the exhaust man said that he can not cut or undo anything before the cat. Which is ok with me cause I bought the extra 3yr bumber to bumber warranty. I need to know where you guys got your super 44 flowmaster did you have your exhaust man order it or did you order it offline and have him put it in. Last but not least should I run it out behind each tire on a 45/slant angle or just turn it down under the bed. Im not a big fan of straight out the back.
I would dump it under the bed, thats what I did, sounds real good. I have a super 40 though. Probably sound better with the 44. Look around online before you buy, thats what I did and found a great deal.www.autopartswarehouse.com $80 free shipping, cheapest I found, not sure what autozone charges.
i had one on my 02 dodge dakota r/t and turned them almost up to where it would bounce straight off the bottom of the bed and it was really loud. if thats what your going for u can do that. on my chevy i ran duals and cut them off right under the roll pan so you cant see the pipes at all and it sounds great.
That is the breakdown. If you had the same system and the onlydifference is the muffler, that is how loud they are.The outside and inside noise go hand in hand,the loudest outsideis the loudest inside.
