forgotten location
Old Jul 13, 2008 | 5:30 PM
definity78's Avatar
Default forgotten location
I have a 92 silverado 5.7. and this is stupid but I forgot were the battery cable hooks to on my engine. I tried the chassis and it made a ground wire smokes. so a fast answer would be helpful.
Old Jul 13, 2008 | 6:29 PM
CharlyG's Avatar
Default RE: forgotten location
The positive or negative lead? The negative or minus goes to the metal part of the engine or chassis as a ground. the positive side typically goes to the starter solenoid or alternator, depending. I'm not a true mechanic, just trying to get you a fast answer. USUALLY THE SHORTER WIRE IS GROUND, OR NEGATIVE, but not always.
- means ground, earth, no voltage, no potential. + means hot, 12volts present between it and ground. You should not get sparks attaching a ground wire, unless there's a heck of a lot of current being drawn, which shouldn't be the case.
bud1tig2
Oct 29, 2018 9:53 AM
dohhahner
Nova & Chevy II
Mar 25, 2014 6:41 AM
bud1tig2
Jul 14, 2011 7:45 PM
dhuberasu
HHR
May 5, 2008 12:13 PM
