Fouled plugs... :( and lots of other problems
#11
RE: Fouled plugs... :( and lots of other problems
so it turns out my act is covered under warranty still so its at the dealership getting fixed for free... well untill they change the 02 sensor and the fuel filter lol thanks for the wisdom all
#13
If the cat has failed while still under warranty then something has caused this failure and while replacing the converter may make the engine run better you will probably still have the original problem that caused the cat to fail in the first place.
The most common culprit is a leaky intake manifold gasket.
stevemaman
August 27th, 2012 5:20 PM
tat2dup81
November 7th, 2009 9:38 PM
dmetcalf
June 18th, 2009 3:35 PM
