Front end update
Old Jan 21, 2016 | 3:55 PM
elgrandioso01's Avatar
Post Front end update
Along with the other problems im having i need to do a little updating to my 2006 Silverado LS ext cab 4x4 suspension etc... What all should i look at replacing as far as suspension/steering system go. It has 140k on it. From the looks of it nothing has ever been replaced.
Old Jan 21, 2016 | 10:40 PM
cleveland63b's Avatar
Is it rack and pinion or conventional? you could start by jacking it up so the tires off the ground then grab the tire at 6 and 12 o clock and slightly rock it, if theres play your wheel bearing or balljoints need replaced then do the same at 3 and 9 to see if any rod ends are loose
