fuel economy
Old Aug 15, 2008 | 2:32 AM
bl89tbi's Avatar
Default fuel economy
Hi
I have 1989 4wd Blazer Silverado with a 350 TBI and I love everything about it, except it's thirst! I drive 90% countryroads, mostly on cruise at 55 mph/ 90 kmh, not many hills. I get, at best, 16 mpg/1,5 L/Km, but average 13 mpg/1,8 L/km.
Is this normal for this model?
I have changed the thermostat, with no change in fuel consumption.
What else is there to do?
What regulators, mechanic, elctric or otherwise can I check?
Old Aug 15, 2008 | 6:09 PM
wellmax's Avatar
Default RE: fuel economy
MPG Improvement[/b]
Run tire pressure 3-4 psi over std.
Change all drive line systems to synthetic oils
Add K&N air filter or one similar for better air flow
Give it a complete tune up using all AC Delco parts
Add 1 can of seafoam fuel cleaner to tank on the next two fillups.
Change fuel brands, some say it does make a difference, try shell, mobil, etc: alcohol in fuel will hurt your mileage.
Drive it like your sainted grandmother would drive it, slow starts, no run and gun.
For every 5 mph over 55 mph you start losing about 1 mpg.
It takes fuel to move heavy iron, it takes even more fuel to move heavy iron fast.
Good luck and stay safe,
I am seeing more seat time on my motorcycle.
Old Aug 15, 2008 | 7:50 PM
itlldue's Avatar
Yes.
Old Aug 17, 2008 | 2:22 AM
therewolf's Avatar
Check your differential ratio, 342s are optimum for highway mileage, but cost 1500. to 2000.$ to change. Also, if you change from higher ratios, your towing,offroad, and low-end/hi-torque will be greatly reduced. If it's not hauling trailers, and mostly on the highway, this gear change couild help you.
Old Aug 17, 2008 | 11:12 AM
bl89tbi's Avatar
Run tire pressure 3-4 psi over std. Check, donne that.
Change all drive line systems to synthetic oils. Check.
Add K&N air filter or one similar for better air flow. I,.. consider it.
Give it a complete tune up using all AC Delco parts. How complete is a complete tune up?
Add 1 can of seafoam fuel cleaner to tank on the next two fillups. Check.
Change fuel brands, some say it does make a difference, try shell, mobil, etc: alcohol in fuel will hurt your mileage. Check.
Drive it like your sainted grandmother would drive it, slow starts, no run and gun. Almost check here.
For every 5 mph over 55 mph you start losing about 1 mpg. Check.
It takes fuel to move heavy iron, it takes even more fuel to move heavy iron fast. Check.
6.5 out of the suggested 9 adjustments are already in place and that has given me the result I started my question with.
Perhaps I am looking for a miracle?
Changing the ratio for 2000$ ? No, that would set me back half the money I paid for the ride.
Maybe gasoline is finally starting to be priced at the high level of appreciation that I hold for it? I won't cut down on driving. I'll just make sure I enjoy the luxury of doing so, a bit more.
And if I come up with a radically better way of enjoying V8 performance with lesser gas bills, I'll let you know!
bracket boy
May 21, 2007 10:09 AM
Skrappi
May 1, 2007 1:33 AM
Klicker
Jul 17, 2006 8:14 PM
