Fuel pump HELP!!!
I need help!! I recently purchased an '03 Silverado 1500, 5.3 V8,4x4, Z-71. The fuel pump needs to be replaced and when I took it to the shop they told me that the fuel pump itself (no labor) would cost $465. When I look up the price going to Auto Zone and Advance Auto, the prices are around $249-$250. The auto shop it telling me that it needs to be a "deeper" or "longer" fuel pump than the ones I am being quoted when I shop around myself. But even when the vin is looked up "Z" it only brings up one certain type of fuel pumps in both places. Has anyone ever heard of this or am I getting screwed over by the repair shop?
My father is a mechanic and I am no dummy when it comes to certain mechanical work but I have never in my life heard of having to have a deeper fuel pump. Especially when the major part stores show the same thing. Thank you for the response
Realize one thing, shops are going to make money off parts they install. This sounds like a ploy to sell you a pump. I am NOT saying they are ripping you off, but giving you a line on the cost instead of telling you they make $ off parts the sell/install.
I realize that shops are out to make money but my only question is if anyone has ever heard about a deeper fuel pump as opposed to a normal one that apparently every auto parts store sells?
Professional Mechanic
Only use an AcDelco or Delphi pump anything else should be considered junk. Most fail with in the first year. You can not buy a good pump at Advance or Auto Zone. The absolute correct pump can be identified by the RPO codes in the glove box. FYI at work we can buy most Delco or Delphi pumps for 250-280 and the have a list price (recommended price to customer) of around $450. With that being said their price is about right. I have no idea what they are talking about with a deeper pump.
Hint: One way to get the labor done for free, is to buy the part yourself, and find technical school in the area with an auto class. They'll do it for a grade, can't mess it up, the teacher is right there.
These are my choices:
Airtex -Complete fuel pump module assembly and strainer = 264.99
AC Delco - Notes: Fuel pump code "TCF". - 302.99
Delphi: Fuel Pump Assy - (Electric In-Tank Type) - Actual MFG OEM<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl00 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl00_h dnTextDetail" type="hidden" value="DFPFG0053_0344357008">
Part Number: DFP FG0053
Product Line: Delphi Fuel Pumps
IMPORTANT INFO: Stamped TCF,w/ EVAP Emissions 296.10
Fuel Pump Assy - (Electric In-Tank Type) - Actual MFG OEM<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl01 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl01_h dnTextDetail" type="hidden" value="DFPFG0466_0388222962">
Part Number: DFP FG0466
Product Line: Delphi Fuel Pumps - 359.10
Fuel Pump Assy - (Electric In-Tank Type) - Actual MFG OEM<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl02 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl02_h dnTextDetail" type="hidden" value="DFPFG0271_0344357009"> Part Number: DFP FG0271
IMPORTANT INFO: Stamped TCU,w/o Evaporative Emission - 296.10
Fuel Pump Assy - (Electric In-Tank Type) - OEM Equivalent<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl03 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl03_h dnTextDetail" type="hidden" value="NFPP76108M_0202371024"> Part Number: NFP P76108M
Product Line: NAPA Fuel Pumps
IMPORTANT INFO: Due to Electrical Requirements, Fuel Pump Wiring Harness Replacement is Strongly ...More - 242.10
Fuel Pump Assy - (Electric In-Tank Type) - OEM Equivalent<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl04 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl04_h dnTextDetail" type="hidden" value="NFPP75014M_0332663686"> Part Number: NFP P75014M
IMPORTANT INFO: w/o Evaporative Emission,Except Heavy Duty 2" Body Raise,Except Export - 242.10
Fuel Pump Assy - (Electric In-Tank Type) - OEM Equivalent<input name="ctl00$ContentPlaceHolder1$rptrProducts$ctl05 $hdnTextDetail" id="ctl00_ContentPlaceHolder1_rptrProducts_ctl05_h dnTextDetail" type="hidden" value="NFPP74835M_0332666889"> Part Number: NFP P74835M
IMPORTANT INFO: w/ Evaporative Emission,w/ Pump Code TCF,Due to Electrical Requirements, Fuel Pum...More - 237.60
mangomanj
August 17th, 2014 9:51 PM
BRB
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
treasurehunter01
January 11th, 2009 11:33 AM
ross_boss08
August 4th, 2008 2:41 PM
