Fuel pumps
Fuel pumps
After doing the cam and crank sensor the 2000 Silverado 1500 5.3 engine still won't start. Do fuel pumps go out all at once? We were driving on the freeway and all of a sudden nothing, the truck just quit. We'd wait awhile it would start and then quit after awhile. We'd wait and it would start. Now it won't even start. So I am thinking that leaves the fuel pump. Replaced the fuel filter already. What do you think? Thanks in advance.
Yep I would say fuel pump. My 99 did the same thing when one day it wouldn't start but then I let it sit and it fired up, but one day coming home from work i was just driving and then nothing and the truck just shut down on me. When these fuel pumps go they go at once. I pulled the bed off when I did mine because I found it easier then dropping the tank. When I did mine it was pretty easy all together. Let us know if you have troubles or anything and once again I think it is definitely your fuel pump.
Also if you want to check, just get some one to turn the key to the on position and you put your ear against the gas tank or near the fill tube and listen for that fuel pump. You not going to hear anything if it is bad.
Fuel Pump
Make sure you buy a good pump Delphi, A/c Delco and not some chinese crap that you'll be changing again in a year or less. Anyway I have 3 Silverado's and have replaced the pump on 2 of them. I removed the bed as it was easier to do the repair. New pumps come with a new connector that you have to wire in place. I soldiered and shrink wraped each electrical line and then shrink tubing over the group of wires to weather protect it. I also replace the evap selenoid with the updated one as they are prone to fail. I checked E-bay for my parts and got them a lot cheaper than local stealers and parts stores. Just shop around for the best price.
No that price isn't bad, just not sure if that will work. One person said yes because it is 100 psi. I just have to make sure what we get will work on the truck. There are 60 psi which one person said won't work on the Silverado cause the psi wasn't high enough. I don't mind buying it, just want the right one. lol
You can rent a fuel pressure tester at autozone for about $150 and then when you bring it back they will give you all your money back. This is an option if you don't want to own a fuel pressure tester. Also, they are available at just about all the autopart stores.
