Fueling Issue
Old Mar 17, 2011 | 11:20 PM
JSMaxon's Avatar
Default Fueling Issue
My 2006 Silverado doesn't seem to want to take fuel even when the tank is empty. There is a loud hissing coming from the filler neck and the check engine light is on. Any ideas what the issue may be?
Old Mar 18, 2011 | 8:03 AM
nauticstar87's Avatar
try to get the code ran, autozone runs it for free. Prolly have a clogged vent line from the fuel tank. Air has no where to go but back out the filler neck, making the gas pump shut off.
Old Mar 18, 2011 | 9:44 AM
basilkies's Avatar
Clogged fuel vent will make the check engine light come on, so will leaving your gas cap off when you start your car. I was told the light will go off if there is no problem, but it takes over 100 cycles, meaning starting and stopping your car over that many times. Pretty stupid, huh?
Anyway I betting you got a twist or something plulgging your fuel line vent. Did you go through a lot of mud or bunch something up under your fender or maybe it's just a defect showing up in the vent line. It should be cheap to fix and a decent mechanic shop should be able to turn off the check engine light when they do it.
Old Mar 24, 2011 | 12:19 PM
Official GM Rep
JSMaxon, have you been able to get this issue resolved?
Jeff Morris, Chevrolet Customer Service
lost_in_alabama
Avalanche
Dec 11, 2011 4:35 PM
jayme0927
Feb 2, 2010 4:20 PM
Surftrash10
Oct 30, 2009 8:49 PM
atjohanssoj
Feb 9, 2007 9:05 PM
atjohanssoj
Feb 5, 2007 3:12 PM
