Gear Ratio Question
I'm trying to figure out what my gear ratio is....93 Cheyenne 1500 extended cab stepside 4x4....The sticker in the doorjam doesn't say and the sticker in the glovebox is all rotted away. If it helps any, I have the 14 bolt rear end. How can I figure out my ratio? What would be the normal stock ratio? I don't think my truck has the towing package on it either.
You could jack the rear of the truck up off the ground and put the truck in neutral and spin the drive shaft if the drive shaft truns almost 3.5 times you have 3.42 if it turns about 3.75 tiems you have 3.73 and if it turns just over 4 times you have 4.10 and the wheels should only turn once
Actually it doesn't need new oil. I just spent quite a bit on Lucas for it about a month ago and put it in....I think I'll go with the jackstand idea. seems easier.
Might not be stock gears though on the side of your ring there should be a number stamped. If you take the cover off let me know what it says. There is not a tag on the rear pig?
Classifieds Moderator
TruckForums Liaison
TruckForums Liaison
When driving 60 miles per hour, what are you revving at??
1500rpms= 3:42 Gears
2000rpms= 3:73 Gears
2500rpms= 4:10 Gears
I'm assuming you have a tachometer though... My 92 doesn't!
I don't have factory size tires, so that would change my rpms at different speeds right? I have 33" tires
NorthWoodsDave
10
May 8th, 2022 12:41 AM
