General ac help...
Old Jun 2, 2010 | 2:56 PM
jlee989's Avatar
Default General ac help...
My wife's Equinox a.c. has been acting up. When she drives the car over 30 mph the ac blows cold air however, if she sits in traffic idling it does not necessarily blow hot air but luke warm air or slightly chilled. I picked up a can of Freon with the gauge to hopefully just recharge the system. When I hooked it up the low side line the gauge almost pegged out and was way over pressurized. At first I was thinking the gauge was defective…I tired it on my truck witch turned out to be fine. The ac clutch does engage so the compressor is not froze up. So I'm thinking there is a glog some where. I'm going to try to pull the hoses and change the expander valve then re charge hoping this will rid my high pressure problem. I was wonder if anyone else has had this problem and maybe a remedy of fix?
Old Jun 2, 2010 | 7:49 PM
LARIDERS's Avatar
when you had it hooked up did you have the car running with the a/c on max? when checking with a gauge the a/c has to be on max and the car running. if you did check it right I am not sure why there would be that much pressure. did the other owner not know what they where doing when they where filling it. if the system is over filled then it would work better with higher rpms. the higher rpms will lower the pressure. really high pressure will kill the a/c comp.
Shaffer201
2014 - 2018 (GMT-K2)
Aug 13, 2014 7:55 PM
mørketid
Nov 2, 2006 11:35 PM
dover78
Jun 11, 2006 11:34 AM
