gmc
Old May 30, 2011 | 8:41 AM
highwayhauler's Avatar
Default gmc
i have a 2009 gmc sierra 4.8l 1500 2wd pick up how can i enhance the performance of it it has 9,642 miles on it, with an automatic transmission with traction control and tow pack? plz help me
Old May 30, 2011 | 1:19 PM
Mille Racer 69's Avatar
Well the sky is the limit, it depends on how much money you wanna spend.
you can start by getting a cold air intake, I like volant and airaid.
you can get a big bore kit and bore it out to make it a 5.2-5.6 liter.
you can put throttle body spacers in.
You could upgrade the throttle bodies (not sure how big the stock ones are)
you can install 11:1 high compression pistons with adjustable cam sprockets
to take full advantage of the additional compression created,
but you will have to use supreme gas from then on.
you could install a turbocharger for a very nice power boost, and it will also help
you get better gas mileage whilst cruising too.
Old May 30, 2011 | 5:33 PM
country_09's Avatar
put a k&n drop-in filter in it...airaid jr MIT tube, open the exhaust up on it and take the stock muffler off, longtube headers, get a cam installed and then get a custom tune to tie it all together.
throttle body spacers won't do anything but give a good whistle, throttle bodys themselves flow enough for the truck up till 500 HP or so I believe and if you want you can do the big bore kit and the turbo but with what I gave y
Old May 30, 2011 | 5:34 PM
country_09's Avatar
throttle body spacers won't do anything but give a good whistle, throttle bodys themselves flow enough for the truck up till 500 HP or so I believe and if you want you can do the big bore kit and the turbo but with what I gave you, the truck will run but then you'd want to do tranny upgrades to keep up with it if installin the other stuff
hawk265
Dec 18, 2007 6:49 PM
JGMIKK
Feb 27, 2006 7:33 PM
kcrue
Feb 25, 2006 1:30 AM
