graid assist engine brake
my 2017 silverado has a grade assist brake, It would kick in going down hills. I know how to disable it, but didn't this time. Going down it kicked in and did it's job slowing me down. At the bottom of the hill never kicked off and still hasn't. Any help would be appreciated.
The grade brake assist is actually controlled by the ABS module using the hydraulic circuits - it’s not an engine brake. If it’s not turning off by pressing the switch, it could be due to a shorted or damaged circuit, module malfunction, or input from another module.
The best chance for diagnosis is to have a shop pull codes from the entire system. Because the system utilizes ABS circuitry for control, any inputs that affect ABS could be the reason it’s stuck on. Brake and accelerator pedals, cruise control buttons, steering position sensor, PCM/TCM controls and sensors, and so on can all affect ABS operation.
Any shop can pull codes from all the modules that could be affecting the system. You can always tell them you only want codes read or to call you first before making any repairs.
oilcanhenry (October 14th, 2020)
Fishinfooleric10@aol.com
December 2nd, 2012 8:54 PM
mcdavidhome
August 25th, 2011 1:35 PM
jrg777
December 9th, 2008 6:21 PM
