Hard starting 1996 Silverado
I have a 1996, always maintained very well Chevy Silverado, it has the 5.0 liter engine. The issue is I have been having problems with it hard starting. The temperaturte outside has nothing to do with it. As long as I start it every day its O.K. but it just takes to many cranks for it to turn over. Could it be the fuel pump or possibly a filter being clogged? I spray in a little bit of starter fluid and it starts up. Let the truck sit for a few days and its very hard to start.
does yours have a throttle body,if so my 5.7 liter does the same it is very easy to start first try the any time after that it cranks and cranks before it hits...i put a fuel pressure regulator on it and i can turn on the switch and it builds up pressure then when the pump kicks off it looses it . i have herd from a few people it is the spyder injectors. under the throttle body...
hey chiming in here..I feel my truck is doing this also. How do we add an inline check valve? Where do we get it
Garon
Nov 21, 2011 8:18 PM
