Haunted Horn
Hello -
my horn seems to have a mind of its own - for the last month or so - it never fails about 2 times a week- around 2am, my horn on my 2000 Silverado sticks on (truck is turned off and I'm sound asleep) - it will honk straight for several minutes - most of the time it just turns off on its own -
last night when this happenend, I found if I put pressure on the brake (light pressure does fine), the horn stops - let off the brake and it goes back on - this seems to be the only thing that will make it stop - however, it will not stay off tell it feels like it wants to -
To get this to stop - I've tried turning the truck off/on - messing with the keyless remote - pounding on the horn -
It seems - this may of all started when my battery went bad - the post fell off leaving me sitting in a parking lot -
I changed batteries and everything else has been fine except this dang horn issue (I don't know if the battery issue had anything to do with it) -
My first question - an easy way to shut the horn up (take out a fuse or disconnect a wire)
and second - what is going on?
any suggestions are welcome!
thanks!
jon
thanks!
jon
i had a 95 buick. used 2 do da same frm time 2 time yet it suddenly stopped.. i think da prob is frm da wiring, or switches. btw do u have an alarm system in ur car, cuz sum alarms just jam up da horn.
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
Dec 26, 2007 9:23 PM
