headlights
Old Feb 25, 2010 | 12:50 AM
gotstylez's Avatar
Default headlights
i wanan go from my stock lights to these
http://cgi.ebay.com/ebaymotors/94-98...Q5fAccessories
it says Modification May Require For Using HID Lighting System.
so what exactly does that mean i have to do to use them or any HID light
Old Feb 25, 2010 | 1:22 AM
nauticstar87's Avatar
Modification means, Break out the Duct Tape... Can't help ya on this one...
Old Feb 25, 2010 | 1:34 AM
gotstylez's Avatar
ducttape and hammer right? lol
Old Feb 25, 2010 | 7:14 AM
cams 98 silverado's Avatar
from what i have seen on these, it seems they mean your hid bulb may be longer than what can fit in this housing so you may have to shim it. i do not think that you will have an issue. the only thing i heard that happens with these is they leak bad. when you get them put a bead of silicone sealer around them for good measure. and i wonder why the high beams have the halo not the lows. personally thats weird but o well. next thing is look at the engrish on the ebay list. Made by OEM Approved Manufacturers With Quality Meet.well you cant go wrong with quality meet.
Old Feb 25, 2010 | 11:02 AM
maxxman04's Avatar
ah-he-hemm. duct tape and a hammer? refer to my signature. it's duct tape and baling wire!
Old Feb 25, 2010 | 12:15 PM
gotstylez's Avatar
ahh ok so its just the headlight itself that needs modded and not my system itself. i dont know if ill go with those exact headlights but something close.. i like the way they look! ..and how about duct tape bailin wire and a hammer?
Old Feb 25, 2010 | 6:17 PM
s34n's Avatar
that same message came with my headlights and i didnt have a problem. only problem i had was with my fogs and that was because the o rings that came with the new bulbs were bigger than the stock ones so i just put the old o rings on the new bulbs lol. everything should fine tho. i found out that my projectors that are on the inside of the headlight so i've been blinding people with the high beams on the new lights lol. oh well hid kit should be here monday or tuesday. i dk why my projectors switched spots on the new ones compared to the old ones.
jclee1014
May 24, 2013 2:19 PM
David_lee1993
Nov 1, 2012 11:06 PM
Medic2891
Mar 30, 2008 1:12 PM
brian213
Feb 4, 2006 5:34 PM
