Heater/Air Problem
Old Jan 2, 2008 | 7:08 PM
ryanm91's Avatar
Default Heater/Air Problem
I have a 90 chevy 1500 pickup
The problem i have is that you select the air mode say the defroster and the air does not blow out the defroster
It also will no blow out the vents very hard even on high
It will not blow out the floor very hard even on high
Old Jan 2, 2008 | 7:18 PM
ZX1100F1's Avatar
Default RE: Heater/Air Problem
Does your truck have the elctronic control head or the simple HVAC dials?
Can you hear the blower kick up as you increase the fan speeds?
Old Jan 2, 2008 | 7:24 PM
ryanm91's Avatar
yes its electronic and i can hear the fan kick up it just seems to be going nowhere
Old Jan 3, 2008 | 6:22 AM
FlapJack's Avatar
Sounds like the ducting behind the dash is old. Mid 90s vechles and older used cheap thin abs plastic ducts wrapped in a sock. The problem is that over time the heat shrinks the duct, like shrink wrap for wires. It's connections warp and the air escapes behind the dash. Otherwise, the cheap foam and sound deadening fabric could have dries and is blocking the inlet to the fan blower.
If the blower is belt driven, the belt itself may have stretched or broke. Usually these fans are direct drive, where bearings in the shaft may have rusted and siezed. Try checking the fan to see if it spins freely. Behing the glove box, above the passanger's feet.
Old Jan 3, 2008 | 10:49 AM
ryanm91's Avatar
ok i will thanks
methods
Nov 29, 2017 2:25 PM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
dmgguy
Sep 24, 2009 3:18 PM
Perrin123
Jun 7, 2009 4:11 PM
mcbuncher
Dec 28, 2008 8:44 PM
