Heater blower moter only works on high?
Hey guys, need some help here. I've got a 2001 Silverado extended cab 4.8L pickup and I have a problem with my heat and AC. I have a control **** from 1~5 for my heat and AC but I get nothing from 1~4, just 5 works and thats on high. Is this a control problem or a blower problem? Any help would be appreciated.
There are couple threads in the Tahoe section about this kind of a problem. What fixed theirs was replacing the resistor on the back of the blower motor, maybe it will work for you.
Thanks for the replies, after some google searches I found it to be the Blower Motor Resistor. $28.00 and 10 minutes later it's all fixed up.
...it is a common problem because it is a throw away part...as it is used it slowly destroys itself and will need to be replaced every do often
had the exact same problem....blower resistor is what fixed it...took like 20 minutes to install and that was just with a gerber multitool cause i had nothing else♠
brenande
January 27th, 2008 12:40 AM
02Lightning
November 23rd, 2006 1:21 PM
