Heater blower moter only works on high?
Old May 9, 2008 | 8:13 PM
dylskee's Avatar
Default Heater blower moter only works on high?
Hey guys, need some help here. I've got a 2001 Silverado extended cab 4.8L pickup and I have a problem with my heat and AC. I have a control **** from 1~5 for my heat and AC but I get nothing from 1~4, just 5 works and thats on high. Is this a control problem or a blower problem? Any help would be appreciated.
Old May 10, 2008 | 2:08 PM
old dog's Avatar
Default RE: Heater blower moter only works on high?
sounds like a heater relay problem .
Old May 10, 2008 | 2:21 PM
northey87's Avatar
There are couple threads in the Tahoe section about this kind of a problem. What fixed theirs was replacing the resistor on the back of the blower motor, maybe it will work for you.
Old May 10, 2008 | 3:10 PM
dylskee's Avatar
Thanks for the replies, after some google searches I found it to be the Blower Motor Resistor. $28.00 and 10 minutes later it's all fixed up.
Old May 10, 2008 | 5:33 PM
northey87's Avatar
That seems to be a common problem.
Old May 11, 2008 | 9:34 PM
74chevy4life's Avatar
...it is a common problem because it is a throw away part...as it is used it slowly destroys itself and will need to be replaced every do often
Old May 12, 2008 | 12:39 AM
xx13xx's Avatar
had the exact same problem....blower resistor is what fixed it...took like 20 minutes to install and that was just with a gerber multitool cause i had nothing else♠
craftsmanmike76@yahoo.com
Chevelle & El Camino
Apr 5, 2013 5:13 PM
kevin3251
Jul 8, 2010 8:30 PM
OnDaGround
May 6, 2009 10:34 AM
brenande
Jan 27, 2008 12:40 AM
02Lightning
Nov 23, 2006 1:21 PM
Top
Follow Us
