Heater motor
Old Dec 4, 2011 | 11:43 AM
LloydBarker's Avatar
Default Heater motor
I have a 2001 Chevy Sliverado 4 door. The heater motor runs on all speeds, but does not blow out the vents (front or back) hardly at all. Could this just be a hose off?
Old Dec 4, 2011 | 12:05 PM
adam86107's Avatar
It could also be the blend door actuator stuck closed on the hot side. However, if your truck has climate control this is likely not the issue if both sides are messed up.
Old Dec 4, 2011 | 2:05 PM
yes both hot and cold are same
Old Dec 4, 2011 | 2:12 PM
adam86107's Avatar
As in neither works?
Old Dec 4, 2011 | 2:14 PM
correct. temperature works on both hot and cold and the motor runs fine, but the air does not blow hard out of the vents.
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
mathblaster
Nov 2, 2009 5:33 AM
BlackhawkCrewchief
Oct 11, 2009 10:26 PM
ljwnevpl
Nov 22, 2006 4:30 PM
Daniel
Feb 15, 2005 8:27 PM
