heater not blowing hot air in my 2009 Silverado crew cab
Old Oct 26, 2012 | 11:24 AM
eddie33m's Avatar
Default heater not blowing hot air in my 2009 Silverado crew cab
Hello all,
I'm new here so I'm not sure if i am in the right place.
I am having a problem with my heater blowing hot air in my 2009 Silverado crew cab. When I turn the **** to hot air it doesn't blow hot. It is blowing air out, it is just not hot. Can anyone help me out here and point me in the right direction?
Old Oct 27, 2012 | 10:45 AM
Sounds like it could be a bad blend door actuator or a clogged heater core. Touch both heater hoses when the engine is at temperature. If they are both hot the heater core is not clogged. If one hose is hotter than the other it is clogged. The blend door actuator is under the dash. Not sure exactly where under the dash on the 09.
Old Oct 30, 2012 | 8:31 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> eddie33m,
I agree with "oldchevy". Based on your description, it sounds blend door related.
Please keep us posted.
If you have additional questions, please feel free to contact me privately.
Louis
GM Customer Service
Old Oct 31, 2012 | 11:07 AM
eddie33m's Avatar
Default Blend door actuator may have been wrong one
I took off the blend door actuator and I'm not sure if I took off the correct one or not. The one I took off was just above the gas pedal. The part I took off worked where the air came out from, i.e. the feet, both feet and face, defrost and feet, etc. It didn't control the air temperature. Did I pull the wrong part? Now I can't get it back on correctly. my luck!
TahoeMatt
Oct 15, 2014 4:10 PM
Felix C
Sonic (Aveo)
Sep 24, 2014 7:46 AM
philhill61
Apr 21, 2014 11:06 AM
Farmerluke
Jun 25, 2013 8:13 AM
ChevySilv91
Jul 5, 2010 11:57 AM
