Help!!!!!!
Old Apr 26, 2011 | 6:35 AM
bill4169's Avatar
Default Help!!!!!!
I have a 97 K1500 with a 5.7. the other day the truck started missing and lost power. I changed the fuel filter, cap and rotor. Still no better. It idles fine soon as you step on the gas it bogs down and backfires through the intake and exahust. I checked the tps and the idle control both are ok. Also I checked the fuel pressure and its 60psi. any help would be great
Old Apr 26, 2011 | 9:59 AM
OLD WRENCH's Avatar
How old are the plug wires?
Old Apr 26, 2011 | 10:25 AM
bill4169's Avatar
The plugs and the wires have about 3 thousand miles on them.
Old Apr 26, 2011 | 5:26 PM
Hunt4X4's Avatar
how many miles does the truck have? could be plugged fuel injectors
Old Apr 26, 2011 | 5:42 PM
BAGnDRAG-K5's Avatar
How exactly did you check the TPS and the IAC sensors?
Old Apr 26, 2011 | 6:36 PM
Big Chuk's Avatar
Sounds alot like like a plugged Catalytic Convertor.
Old Apr 26, 2011 | 7:51 PM
bill4169's Avatar
I think I found the problem. I went back to the fuel pressure and tested it again. I had the truck running and after a couple of minutes it droped to about 20psi than when I hit the gas it went to almost zero.
luni1974
Apr 29, 2014 2:31 PM
josh46970
Jul 28, 2011 12:19 AM
vwwebb
Jan 23, 2011 5:03 PM
kenney
Jan 31, 2009 5:29 PM
jharper
Dec 11, 2007 4:15 PM
