Help installing brake controller
I have a 97 Chev K1500 with the tow package that I want to install a brake controller on. I have the blue wire in the harness at the rear of the truck. Where/ how do I find it at the front? Is it under the dash, under the hood, a little of both? Manual has no helpful info and the dealer wasn't much help either. I figure if I have it at the back of the truck, it's gotta end at the front somewhere.
TIA!
Scooter
TIA!
Scooter
RE: Help installing brake controller
it should be up near or just under the power brake booster tied up with wire tie .should have a orange wire also for auxiliary power 12 volt lead .
Thanks William! Which wire is the "cold" wire for the brake switch? My Manual doesn't show the brake switch?? I will probably figure it out when I get to the switch, figured if someone couild tell me it would save methe time fo testing. I do have a white wire at the rear bumper that had a tag that said swch brk or something similar. Does that mean the "cold" wire will be white?
Thanks Again!
Thanks Again!
i cant tell you the color ,you will have to probe the wire with a test light when you push the brake pedal to see which wire is hot or not for the brake light switch.
T-bone
August 29th, 2011 1:16 PM
andystephens2009
July 19th, 2009 1:29 AM
pervitizm
July 6th, 2007 8:40 PM
