HELP need part for TH350
I am rebuilding a TH350 as my first transmission rebuild. Really not that bad so far. BUT.......The detent cable connecting point inside the tranny on teh valve body was broken.........explains why it would not downshift........this is the part the detent cable hooks into and pushes the valve..............Does anyone have one I can buy as i can not find them ANYWHERE on the net.........Please advise..........thank you.
Wayne at johnwaynehoney dot com
Thanks again
Thanks again
Well, if nobody has one of these on an old junk core then is it ok to run without this hooked up? Truck is only driven a few hundred miles a year to go get feed and pull hay trailer out of field to barn........can you run with out the detent cable?
red
CRFrizzell
February 24th, 2007 12:36 AM
