Old Aug 10, 2015, 12:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Help, please: Silverado key won't turn.
Old Dec 27, 2020 | 12:58 PM
  #21
lostmechanic's Avatar
Default same extra piece?
did you ever find out where that little plastic piece went. have same extra part.
Again,... thanks.[/QUOTE]
Old Dec 28, 2020 | 10:40 AM
  #22
therewolf's Avatar
Lostmechanic, Welcome to the Chevrolet Forums.
This thread is from 2013, I doubt anyone is still following it, sir.
Old Apr 23, 2021 | 7:42 AM
  #23
Dingle whooper's Avatar
Default Help
Originally Posted by Mark53
Well,... just FYI.. here's a status update, people...
I removed the white plastic wheel (A) in the middle.
Then, I removed the big black "controls assembly" (B) on the left side (just for the heck of it).
With the (A) removed, I had access to the two torx screws that hold on the ignition assembly (C).
I removed that... and with that assembly in hand, the key works. It can turn.
I put the ignition assembly (C) back, on, and the spare key works,
but the most-used key (quite worn) works rarely... only after playing with it for a while.
SO,... the problem seems to be solved,
but I didn't find anything that caused the problem in the first place.
That's kinda' frustrating.
Maybe the problem will arise again next week, when I'm on the road somewhere.
Any ideas as to what caused the original problem?
Woops... another problem...
In reassembling, I have a spare part...
I vaguely remember that it was a secondary holding/mounting for a wire/cable?
Anybody know where that little plastic piece (about an inch long) goes?
Again,... thanks.
I know this is old but I'm having same issues.
I can not find where this white plastic Part goes (circled in purple)?
any help would be greatly appreciated.
Thanks
Old Aug 30, 2024 | 7:13 PM
  #24
DeeT's Avatar
Originally Posted by actriz45
The ignition key on my Chevy Aveo will not turn. Should I call a locksmith or tow it to the dealer?
I have a 03 Silverado 1500 step side . My daughter drove it last night and it wouldn't start this morning I went out couple hours ago to see n key wouldn't turn after messing with it n try take the bolts out. I got some PB B on the key and just tried to work it with no results. So I a rubber screwdriver handle and tapped where the key enters a few times then I gave it a few more for good measure put the key in pushed it down and it turned and started.. got lucky I guess. Probably need a new key cut n programmed now..
malicen
May 31, 2024 1:23 PM
Pbrouse
Sep 22, 2019 9:50 AM
eycblu
Jul 12, 2010 9:08 PM
oldtimer50
Jul 14, 2006 10:14 PM
