help with silverado body work
Old Oct 14, 2014 | 7:29 PM
nitro27's Avatar
Default help with silverado body work
hey guys im new here and i need help on steps on doing a full body work on my truck, what brands and what size sand paper to start to finish ?
if needed to know i have a 2001 silverado z71 and the rear door has few dings and dents and the rest of the truck sanded down for primer so once all done i would like to spray the hole thing in primer
Old Jan 8, 2015 | 8:55 PM
egutierrez09's Avatar
If its still not too late:
Go with 3M Wet/Dry sandpaper with the big sheets cut them in sections of 4 if your only using a block. Otherwise circular disc for DA.
Get grits from 36 60 80 for bondo shaping and smoothing/ 80 for clear coat only of going down to primer as it will warp if left on spots too long.
120-180 smoothing out fine bondo
320 -400 for prepping surface for primer- use block to get it smooth and flat as possible.
use graphite powder or if you want to, go with a dark or light primer to check imperfections depending on your primer choice.
Aerosol
Jan 26, 2015 10:06 AM
mikekelso99
Jan 8, 2015 9:22 PM
dtizz
Oct 10, 2012 3:09 PM
LeeA
Apr 13, 2012 4:28 AM
