help...too much fuel????
i don't know what to do, all of my plugs are fouled!!!! i don't know whats causing it to get too much fuel....
1998 k1500 z71 350 small block
Do you keep proper mntc (no disrespect)? Any service engine soon light? O2 sensor maybe. There is 4 of them. The 2 closest to the engine (left bank, Right Bank) generally get about 100000 miles before going out. When they go out the engine defaults to a rich mixture.
easy fix, get a supercharger!! but structures right, it sounds like you got some o2 sensors reading a lean condition, making it push fuel into the system
with o2 sensors bad, you'd have had SES light up on the dash.
1. go to any parts store and scope for codes.
2. possibly faulty fuel pressure regulator
3. possibly leaking injector seals, though i doubt all of them go bad same time
4. possibly insufficient plugs, not providing complete fuel burn
5. check your air filter.
how is the general mpg? if ECM is pumping too much in, then you should see significant drop in it.
either way, either replace plugs, or take torch to them and burn all the crap off. you might have had them flooded once or twice, and junk slowly builds up ever since, and with junk build up - they slowly burn less and less fuel.
is there a way to test them, or is it just easier to replace them? i'm going to try that and see how it goes...i've also heard that on these trucks the fuel injectors go bad easily and quickly could that be the case? that they are just opening too much? thanks!
<a href="http://smg.photobucket.com/albums/v465/ducati648/?action=view&current=l_a9c90e0843648e064a2f5c0 d3bbede70.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v465/ducati648/l_a9c90e0843648e064a2f5c0d3bbede70.jpg" border="0" alt="Photobucket"></a>
ORIGINAL: neattouch648
href="http://smg.photobucket.com/albums/v465/ducati648/?action=view¤t=l_a9c90e0843648e064a2f5c0d3bbede70. jpg" target="_blank"> src="http://img.photobucket.com/albums/v465/ducati648/l_a9c90e0843648e064a2f5c0d3bbede70.jpg" border="0" alt="Photobucket">
anyways, ever since i posted my response, i was sort of wondering - what exactly is your plugs fauled with? just pure gas? all of them? or it's something else AND it is damp/smells with gas? cuz you know, it might be fauled with oil(bad gasket) and just slightly soaked with unburnt gasolino, and might fool you.... any spark plug good or bad will have some gas odor...
alright, well I am pretty sure its getting too much fuel because i can just smell fuel all around the engine and i think even in the truck, plus its gulping down fuel like no other...
![Name: l_a9c90e0843648e064a2f5c0d3bbede70.jpg
Size: 44.8 KB](https://chevroletforum.com/forum/attachments/silverado-sierra-fullsize-pick-ups-21/15707d1501540202-help-too-much-fuel-l_a9c90e0843648e064a2f5c0d3bbede70.jpg)
![Name: l_435f4206dbace750c3a9d3a32e53a455.jpg
Size: 50.0 KB](https://chevroletforum.com/forum/attachments/silverado-sierra-fullsize-pick-ups-21/15708d1501540202-help-too-much-fuel-l_435f4206dbace750c3a9d3a32e53a455.jpg)
Promcomp xtreme a/t 37 x 13.5 on an 18 inch american racing wheel....
good news guys!!!! i got the truck running, my injector body was messed up, replaced it and it runs great!!!!!
BrandanDeMamp
April 8th, 2014 7:22 PM
grndslm
April 24th, 2013 11:21 AM
Isaacm1986@gmail.com
August 13th, 2009 11:35 PM
